I have a battery draining issue on AirPods 4 the gen , mismatched battery draining opening. Only used for music listening . the left side battery drain faster than right its bug or I dont know .why there is no charging indicator on while charging or full completed . its just 2 sec orange light blink that’s all
hi bro, similar to iPhone airpods also have optimised charging feature. based on which bud you are using, battery draining will happen gradually and stops charging after 80%. this cannot be manually controlled.
I hope you do have applecare+ to protect airpods from any manfuacturer defect or user damages for 2 years total. if not do get it right away bro.
Continue using the airpods for few more months and in this 2 years you can claim warranty anytime as manufacturer issue if any such battery related issue occurs.
But right now its not a problem dont worry.
Thank u so much for the reply sir
