Airpods automatically connecting even when Bluetooth OFF
Hi bro
I have connected my AirPods to other phone.
When ever i receive or dial a call in iphone the AirPods automatically gets connected to iphone even while the iphone bluetooth is turned off
hi bro, are you wearing airpods or the airpods inside the case? and you are not hearing audio when the call attended correct?
Bro the issue is i have connected the airpods to my secondary android phone and bluetooth from my primary iphone is off. If i receive a call or i dial a call in iphone then airpods is automatically connected to iphone which should not happen as Bluetooth is off
This issue is while im wearing the airpod
Quick switch feature designed to switch to airpods automatically when you are wearing the airpods bro. or when you take it out of the case it automatically connects. its normal. the feature designed to work that way.
Within airpods settings when paired to your iPhone you can change its “Connect to this iPhone” setting to “When Last connected to this iPhone”.
That will prevent the automatic connection.
Also when you turn off bluetoth from inside settings it wont automatically connect with apple watch or airpods when nearby. you can try that too bro.
