If we connect to the some like real me or one plus airpods when i play bgmi there bad background noise if i once turn off and on the mic only the noise stops what problem bro
hi bro, the background noise issue is because of game side bug. as its not present during calls and other apps usage. Have reported by users before too. and check whether BGMI game is updated to latest version.
Else we have to report the same to BGMI Customer Care help section. Only via updates it can be fixed.
Another troubleshooting method is, reinstall bgmi game and see if same issue repeats.
Thank you so much sir for wonderful support
