AirPods Battery 100% But Still Charging – What Does It Mean?
After reaching 100% battery, my AirPods still show the charging symbol in the battery widget. Does this mean they’re still charging, or is it a bug?
Hi bro, that is normal. it automatically cut off after reaching required level. similar to iPhone, airpods also have optimized charging feature. so dont worry. they manage the charging level and speed automatically based on your usage.
