airpods connected notification is popping every time after connected and while using this is so annoying while playing games watching youtube , etc please help me what to do i have attached the photo of the notification popping.
hi bro, it appears only once when we connect the airpods. is your airpods frequently disconnecting and connecting again? which airpods model it is and when purchased?
it is not disconnecting i am getting the airpods connected notification every time for just 10 seconds once my airpods is airpods gen 2 it is still in apple care plus warranty but can yu help to solve this notification issues with troubleshooting please
i tried forgetting and re connecting by pressing the button behind the airpods to reconnect also nothing worked ![]()
Issue could be airpods related bro. kindly visit nearest service center as it still has applecare+ if any hardware issue found they will replace the airpods and check. service technician will check by connecting with your iPhone and recreate the problem.
thank yu ![]()
