Apple AirPods gen 1 charging case lost…don’t know what to do with left and right AirPods …can u plse tell me what is the solution? I want to buy charging case ??? Where I can get it ? Or 1st quality box is enough for charging ?
yes bro. you can get either an individual airpod or the charging case. It could be expensive. do check with apple service center once bro. approximately Rs 7500 may be.
Else check with new one and compare the pricing to decide which one to go for according to your budget bro.
New airpod gen 1 cost 8999 , just bought new one , crazy apple ![]()
Thats good choice. Due to import, spares are expensive bro.
Yes bro agreed , but for a consumer point of view it’s totally wrong , in by macbook air m1 i recently changed the display under warranty (manufacturing defect ) it’s cost 45k , what if its not in warranty means a average consumer need to pay 45k only for display? Crazy apple
Agreed. Hoping the manufacturing of parts starts soon in india. We will be able to see good price difference in service cost bro.
Yes bro we are all waiting for made in iPhone for pro models , waiting for good software upgrade ,
In my M1 Mac 256gb they sell tha nand flash in dual band memory, in now for M2 model the sell 256gb model in single memory , why apple , so they are pushing their own customer to bought higher version, crazy apple
