AirPods Pro 2 ANC not working
Bro Recently on AirPods Pro 2 usb c Active noise cancellation is not working as before.Particularly on firmware version 7B21…What’s your usage point of view bro??
hi bro, I normally keep transparency or adaptive audio ON, I rarely use ANC as it kind of gives me headache after few minutes usage. also to aware surrounding I prefer transparency. Tried ANC just now and its working good with music.
What exact issue you are experiencing? ANC ON still able to hear the surrounding?
The issue is like When I put AirPods on and suddenly it switches to ANC…Earlier I was not able to hear nearby persons noise without music turned on.But now I can clearly hear what they speak.That means ANC is working like Transparency.
Is the adaptive feature is ON bro? do check in airpods settings page. Because if adaptive is ON, it will automatically turn ON and OFF ANC when someone comes near and either they or you speak.
No bro. I always keep ANC on. I have gone to Apple service centre and they accepted that there is a error and gave it for repair.
Normally they provide replacement bro. good to know you have visited service center.
