AirPods Pro 2 audio difference iPhone and Apple TV
I have AirPods Pro two second generation, if I connect my AirPods to my Apple iPhone 15, the sound is amazing and I can able to feel very good difference, but if I connect the same AirPods Pro to 2nd generation with my Apple TV as well as to my iPad app, I could not able to feel the same output what I have been got in my Apple iPhone 15. I have contacted to the Apple support stating that I could not able to feel the same experience while connecting in this two device, they have replied that please disconnect. I mean, please forgot the AirPods with both of the devices and connect it again. They told I have tried it, but still iPhone 15 gives the best audio output while comparing to these two devices is there any issues like this or else due to the voltage generation of iPad as well as Apple TV? This is a maximum output. ? Could you please guide me? I could not able to find whether the problem is from the AirPods or else with the kinds of devices.
Hi bro, if we have lossless audio enabled in iPhone we do see such quality difference between devices. with Apple TV can you check following settings?
  1. Go to Settings > Apps.
  2. Select Music.
  3. Select Audio Quality.
  4. Select or deselect Lossless. Apple TV 4K currently doesn’t support Hi-Res Lossless (sample rates greater than 48 kHz).
and check listening few songs whether the audio quality is improved or not?
