Hi Bro,
Am using Airpods Pro 2 with my 15 Pro.
Battery Performance is good. But my issue is in the Battery Widget the Airpods Pro case and Buds battery level vary abnormally while closing and opening & while using. How to fix this or how to find which is correct
hello bro, with airpods pro buds, they also have optimised charging feature. so airpods automatically manages the charging level based on our usage. dont worry. when the airpods are in the case its charged according to our previous days usage.
Similar to iPhone, 80% and after charging is still managed to protect its battery health.
Continue using it the way you want and you will notice the changes on battery level in coming days.
Bro i understand that. But my issue is When i close the Airpods Case battery is 25% again when i open it shows 80%
This sounds like a bug bro. iOS version updated to iOS 18.3.2?
