Hi Bro last week I purchased airpod pro 2 with care plus. I have doubt how to check battery percent of the airpod and my firmware version is
Version - 7B21
Case - 65.3.0
Do both airpod and case both will update or only airpod alone will update as case version are same for the past 7 mths when checked in internet.
hello bro, airpods case and the buds also gets updated automatically. we dont have to do anything. simply use it normally and it gets updated in the background. you can check the latest airpods firmware version here at apple website.
