hope you are doing good!
I got my AirPods pro2 in Dec 2022.
For the last couple of days my AirPods gets disconnected in middle of an activity…For example if am listening to a song suddenly it disconnects … if watching YouTube suddenly it stops…sometimes one side will go off and then immediately after few secs another will also go…
Have you come across a situation like this.
Is this a case of battery health in AirPods is degrading.
Also my right AirPods is not charging proper Or it’s draining faster than the other one.
Apple care + is over
What is the best advice you would give me in this case?
Good bro. thank you. hoping you too. so far no such issues experienced. but if the airpods were used regularly I suspect it could be battery related issue too. we can try based troubleshooting steps like unpairing resetting and pairing it again.
but if issue occurs again, then replacing airpods is the only way. within applecare+ as I normally suggest in our videos, replacing airpods even by last week before warranty ends helps to use it for another 2+ years without issues.
So overall we use airpods for 4+ years in general.
but right now only option we have is checking with third party service center. do check with iDot Repairs, Chennai once bro. google search and find the contact number to call and confirm the possibility of repair.
If repair is done or battery replacement of airpods pro done, you will be able to use it for next couple years.
Welcome bro. recently some of our audience suggested KZ Pro X series IEM Headphones.
Do check review of similar other IEM headphones as the design and wearing comfort will be different than regular headphones. then you may try this out. I am yet to personally try one soon.
