Airpods pro 2 generation type c beeping automatically when not using it.
Airpods pro 2 generation type c beeping automatically when not using it. Any suggestions for this issues?
hi bro, do check in find my app whether lost mode is active for airpods pro 2nd gen.
It is not showing in Find My. I went to an Apple service center in Kovai, and they informed me that some products do not appear in Find My in India. They were trying to convince me of this. Also, since I’m using only a MacBook and not an iPhone, I wasn’t aware of this issue. My AirPods Pro (2nd generation) occasionally beep automatically, even when not in use, approximately every 5 hours.
No bro. airpods pro should be visible in find my app when its paired to your iPhone.
you are using same apple id for both iPhone and Macbook correct?
Do one thing, press and hold backside of airpods case to reset it. hold it for 10 seconds till you see white light blinking. then remove airpods from iPhone bluetooth settings.
Now bring airpods and iphone closer to pair fresh to your iPhone. let me know if the issue solved or not.
I brought iPhone 16 Pro 256GB, now it is showing in Mac and iPhone.
Problem fixed bro?
Yes, bro.
