Airpods Pro 2 or AirPods 4? Which is Best Buy?
Hi bro. I currently have airPods 3.
Duration 2 years.
One side of my airPods is has low sound.
I’m planning to purchase airPods pro 2.
Should i wait for airPods pro3, or airPods 4?
Any suggestion?
hello bro, as said in our recent episode, expecting new airpods release during the september event. so kindly wait and see if airpods 4 released or not.
if in-ear is comfortable for you then going with Airpods pro 2nd gen with offers at around 18K range is good buy.
whichever airpods you buy, make sure to get applecare+. so before end of 2nd year if any break happens we can replace it and get new one. so battery will work well for another 2+ years. so overall you will use airpods for 4+ years bro.
