Bro apple airpods pro 2 la automatic ah volume increase decrease aguthu bro eppadi fix pandrathu update paniten airpods forget kuduthu again connect paniten
hi bro, that is not usual. whats your current iOS version? updated to latest iOS 17.1.1?
Yes bro I am using latest version only but i facing this issue from ios 17 update onwards
do perform all settings reset within iPhone once bro. then check. if problem repeats then we have to check with apple service center once. airpods pro 2 is under warranty?
Yes bro it have apple care plus
Good bro. if its not fixed with above troubleshooting step then we can get it checked once at service center and replace within warranty. This audio up and down problem is there in iOS 17 versions. But fixed in iOS 17.1 and after that.
