bro AirPods Pro gen2 miss pannitan epdi find out pandrathu bro
sad to know bro. nearby iPhone 11 or above devices varanumnga. it has U1 Chip so when someone tries to connect your airpods with their iPhone or nearby iPhone 11 or above model varumbothu it will send location bro. you have to wait and check few hours once in find my app to get any location update. then visit the place to collect your airpods safely.
bro en phone la irunthu remove this device kuduthutan theriyama athanala enaku find my la kaatala ethachi veara option iruka
then its permanently lost bro. now its not possible to find or track it. again unga device la pair aachuna thaan find panna mudiyum. enga lost aachuna therinja physical search pannipaarunga. may help.
AirPods Pro serial number vachi find out pannamudiyatha
No bro. that cannot be used to track. only find my app is the solution.
ok bro thanks
