I buy airpods pro 2nd generation yesterday with extra warranty and connect with my iphone next gone to check the apple coverage in apple website it shows update the date of purchase and i try to update it shows invalidate please contact apple support please help me to update the date of purchase and warranty also bro
Hello Bro. Usually we can update the month and date of purchase by checking with checkcoverage.apple.com website. If you have any issues, then contacting apple customer care toll free is recommended.
They will ask for your airpods pro 2 purchase invoice. Based on the date they will activate the warranty from their side. Don’t worry.
Do call 000800 040 1966
Thanks for the guidance bro i also buy the extra warranty how to check that
it wont have extra warranty bro. warranty status will be shown when you follow above steps. only if there is a problem you call apple customer care.
if you buy applecare+ for airpods, then you can extend the warranty to totally 2 years. to buy apple care+ for airpods you can visit apple service center or call apple customer care toll free bro.
Ok thanks bro
