Hi @Robin bro,
Can you share any good portable airprinter for using with apple products. Please share the product link and your experience if you’ve used any.
I’m using Honor 8x as my secondary mobile and interested in dismantling it to see the parts inside. Can you share any mobile/laptop repair toolkit
I heard about Apple tv leaks that new model launch may happen by this year (2025) end. Is it true ? Whats your thoughts on this ?
hi bro, I havent had any requirement for printer so far. mostly doing digital data transfers. you can check the airprint compatible printers here.
Most of them dont available in india, but brother printers you can find in india. do check with any computer sales showrooms too to see the same model availability once. then you may compare it with online pricing and decide.
I normally refer people to check with service centers and havent tried with mobile repairs myself bro. you can check with any screw set and adhesive tools to seal the phone back again properly. most android phones have one kit and supports with mobile repair toolkit sets for screws and spare removals. You will be able to find them online too.
Yes, Apple TV is due for an upgrade. expecting it around september iPhone event bro. so if its not urgent you may wait and then consider going with apple tv.
