Airtel Thanks App Heating Problem
hi bro airtel thanks app use panra appo mobile romba heat agudu ida yala mobile check panitan 13 , 13 pro max, 14 pro max , 15 plus, 15 pro max customer carela complient panna update la fix agum solranga bro ios 15 versionland check pani irukun still 17.3 ios version varaikum inda thanks app use pana nala heat agudu but my jio appla no issue iduku enna panalam edu solution solunga bro , na same back up use panra nala issue iruka chance iruka
hello bro, App specific issue thaanga. app ku location services disable pannitu use pannipaarunga. you may notice difference.
Location services offla than bro iruku
Location services off la than bro iruku
then app la thaan problem irukumnga. normal heating na thevaipadurapo use pannunga. photos and other apps permission complete off pannitu use pannunga. that will limit resource usage.
