Apple 20w Adapter Heating Problem
Apple 20w Adapter Mobile Charge Pannum Pothu Romba Heat Aguthu bro & Heat Anona Mobile Charging Off Agiruthu bro ! Adapter Vaagi 1 Year Akuthu bro. Adapter la Problem ah irukkuma bro ?
hi bro, sometime namma use pannura power port issue va irukalaamnga. can you try with different port? building la earth line proper a irukungala? or any other electrical appliances in the same building also giving minor electric shocks?
Yes bro power port la problem irukku & Ana Vitula Samsung Mobile Use Panraga 25w Adapter Antha Adapter Heating issue Ethuvem Valla bro.
Difference irukalaam bro. Junction box with fuse mathiri ethavathu irunthaalum use pannalaam bro. Just to check heating is happening again or not. Normal warm temperature is ok, if its overheating then its not normal.
Ok bro.
