Hi Bro,
Iphone 16pro use panran. 50 days aachu. Apple care plus podalama? Venama? Unga suggestion sollunga.
Yes bro. within 60 days applecare+ apply pannalaamnga. suppose 2 years coverage thevaipadum na consider pannunga. just to protect from any big expenses incase of accidental damages.
careful la pathupeenga na thevaipadathunga. also indian unit a iruntha Protect+ consider pannalaamnga before 1 year warranty ending time to extend for one more year.
totally your personal choice.
Protect plus enga bro poduradhu. Ipad ku protectplus ketan ana avunga 60 days kulla podanum nu sollitanga
iPhone ku mattum thaan protect+ 1 year time kulla apply panna mudiyumnga. ipad, mac and airpods ku 60 days from the date of purchase as said in our protect+ video bro. iPlanet service center la once check pannunga. they will guide you further.
Thanks bro
Thank you bro
Hi bro hope you are doing well . i planing to buy a 16 pro max in Qatar . apple care protect can i buy in usa . i will in India but one of my friend in usa so can he purchase plan for me
Hello bro, I am good thank you. hoping you too. yes you can buy applecare+ in other countries by calling apple support bro. they will activate it for your iPhone.
also just an info, kindly create separate post next time to avoid sending notifications to others with our discussion bro. have a good day.
