Apple ID Not Visible in Settings
Hi, Can someone help to verify if the Apple ID visibility issue is fixed in iOS 17.5
Steps to reproduce
  1. Settings → Display & Brightness
  2. Set Text size to very small
  3. GoTo Apple ID → Sign In & Security
  4. Check if you can able to see your Apple ID there.
Thanks
hi bro, I just checked its working fine in my iPhone 12 and 15 plus. Apple ID is visible. You may update and check if its fixed or not. else doing iOS Restore once is recommended to fix such device specific bugs.
