Apple Macbook M2 Pro 8gb 256GB storage - 13 Inch
Hi Robin,
I ordered macbook pro M2 2022 8gb ,256 gb storage . I am quite confused which one to proceed further .
My usage
  1. I dont play games
  2. I need it for editing youtube videos
  3. I used for coding (python,groovy,C#)
Is the above configuration sustains the above functionalities . Require your help
hello bro, its perfect fit. dont worry. just get an external storage with 1TB SSD may be. to store your important files that you frequently access. you can use internal 256GB storage with limited set of contents. to avoid filling storage space. going with 512GB is good, but as you have already ordered, dont look further. just make alternative setup and proceed with the video editing works.
Thank you @iRobinPro bro .
I am get it at price range of 1.02 Lakh . Hope it satisfies my needs
Thanks a lot for the valuable information
Thats good pricing bro.
