My Apple Pencil 2nd gen even though always connected to iPad I find it having 0% battery when I pick it to use .it has been doing this recently
Hi bro, Apple pencil year of purchase?
2023 bro
Its still under warranty. dont worry bro. if its a defective unit they will replace it. kindly visit apple service center in your city and let them check. repair is not possible so they will replace it in a week or two time.
Thank you bro !
I have one more concern
Today I bought an Apple Watch SE 2 from Online Croma store.
When I received the package everything was sealed n new . Packaging said manufactured in June 23 . When I unboxed n turned on the watch it said low battery pls charge to continue is that okay ?
Initially when I entered the serial number to check coverage . It said 1 Aug 24
After pairing with my watch it says 30 Dec 24
Why is this change .
And also I checked the band socket for serial number
There it says
SN number and model A27*** like that with CE label
Sorry for long question n thanks bro
Welcome bro. that warranty change must have happened based on billing date to the seller bro. Not to worry. as you are seeing updated correct date once connected to your iPhone.
We can change it by calling apple support and providing the croma bill copy provided. They will verify your purchase date and adjust the warranty date according
That model number A27… is to identify which series model it is. and if its any other letter like M or N then it will be exact type and country origin.
