Hi Robin, Apple Watch 8 LTE battery health percentage reduced to 97% in 8 months. Is it normal ? Thanks
totally normal bro. continue following the same charging practice you are doing right now, it will be maintained well.
Sure thank you ![]()
Hi Lokesh ,
How was your Apple Watch ? I’m planning to buy latest watch series of Apple.
Hi
Good only but need to bear with 1.5-2 days battery life. Also must follow charging practice which will retain battery health for long ji. Kindly Avoid battery drain and then charge.
Okay . How about activity tracking?
Ya Good
Bought it from online or offline
Offline, @Iplanet
Apple Watch SE vs Apple Watch series 8/7
Ena difference brother ?
SE has all the basic features bro. It dont have O2 monitor or ECG feature. Where in Series 7, 8 models we have those two additional features. If thats not important to you and need a smart watch and fitness accessory to pair with your iPhone. then SE is great choice.
Okay bro . Thanks for the explanation!!
Normal person ku
Watch SE is enough thana bro
Watch 7/8 la irukura all features um vanthurum la bro (except ecg and o2)
SE gps version(44mm) use pana - namba iPhone la Bluetooth always on layae irukanum ahh bro ?
For syncing the Watch data to iPhone watch app !
And Ithunala iphone and Watch la battery difference etha irukum ahh because enoda usage ku iPhone 13 1.5days varuthu Athunala I’m asking
Ungaloda suggestion vachi tha I decide whether I go for cellular or gps version
yes bro. its suitable for normal users. bluetooth control center la irunthu neenga off pannalaam but low power la sync irunthitu irukumnga. not a problem. battery consumption irukum, but romba difference irukathunga. users normal la use pannitu thaan irukaanga.
Okay bro …
enoda fitness and health kaga dha purchase pana pora. Atha Ketan bro
Thanks bro !
hi @iRobinPro
can i buy a apple watch 8 at 28k is it worth for money?
New one on Amazon Bro? GPS or Cellular model?
new one gps bro
30K around price is decent for series 8 model bro. during last month offers it went upto 27K I think. you may consider it. make sure its 45mm model bro.
