Apple Watch battery charging notifications not showing in iPhone
Hi bro, I am using Apple Watch SE GPS 2 nd generation and iPhone SE 2nd generation. But the Apple Watch full charge notifications not receiving in my iPhone. I have tried upair and reset both Watch and mobile but the issue is not fixed.
Hi bro, is the charging notification setting also turned ON on your Watch App - Sleep - Charging Reminders?
Yes bro it is turned on.
Then we should see the charging notification on our iPhone when it reaches 100% and charging completed bro. can you restart both apple watch and iPhone once and try charging it tomorrow. see if you are able to see the notification on iPhone lock screen when charge completes on apple watch.
make sure iPhone settings - notifications - watch app settings are turned ON.
Thanks bro I will try this method and I will update bro.
@iRobinPro This is a bug from watchOS 11, brother. You are not alone;many users were reporting the same in the Apple community forum, and I’m facing the issue as well. Hopefully, we will get an update with a fix.
Got it bro. hoping next week update brings the fix. iOS 18.2 RC just released with plenty of bug fixes.
