Apple Watch Battery Maintenance Tips, Is it Correct?
Usually I get my Apple Watch battery for 3.5 days by doing switch off my watch at night time and switch on in the morning when I go to work .
So wanted to check is it a good practice to switch off the watch at night time and switch on when I need it? Or this will affect the battery life ?
hi bro, I never switched off my battery over the night period. and its totally upto your choice. turning off wont cause any problem, but if you feel like using it for sleep tracking, then you may wear the watch. otherwise you may keep it on night stand or OFF.
Turning OFF wont affect battery health of the watch. just like iPhone, avoid draining it frequently bro. it will be good.
