Apple Watch SE Incoming Calls Notifications Not Working, How to Fix?
Hi,
My i watch se suddenly stopped showing notification for calls. I have reset the watch and tried connecting again. but still no alert on watch. what should i do ?
Hello Bro, can you try restarting apple watch and iPhone once and then check whether incoming calls notifications working or not?
i tried resetting the watch but still didn’t work ? should i reset my mobile as well ?
no need bro. does it happen while using 5G or in LTE network? Is the WatchOS updated to latest version?
i only have a GPS version not cellular. And yes the OS is in latest version only bro
i tried making a call from the watch but it says call failed. But to check connection when i try to ring the mobile from control center of watch, my mobile rings.
iPhone is nearby when you try to make a call correct? GPS watch will work for incoming and outgoing calls when iPhone is nearby and the watch WiFi icon shows its connected.
It got automatically fixed after the recent update bro. Thank you for your time
