I purchased Apple Watch series 9 41mm it’s 15 days old. Battery drain is too high. Night time without anyusage while Bluetooth and WiFi turned off also drain percentage is around 15-18 percent. Please advise
Apart from Siri ( hey siri feature turned off activating only by long pressing) all the sensors are turned off
Hi bro, apple watch normally consumes 10 to 15% overnight, that is normal. but if it goes above 20% then there is an issue which we can try some troubleshooting steps with.
Make sure Heart Rate features and activity tracking are turned ON always.
Charge for 30 minutes around by the end of the day or in morning and continue using it bro. you will see improvement with upcoming updates.
Thank you for clarifying bro…
