Applecare+ for iPad Pro Worth buying?
Hi Bro, hope you’re doing well
I have a few questions regarding AppleCare+.
I recently purchased an iPad Pro 11-inch (M5) and am planning to buy AppleCare+.
I would like to understand the following:
  • How does AppleCare+ work in case of any damage?
  • For physical damage (accidental drops, screen damage, liquid damage), will the iPad be repaired or replaced with a new unit?
  • In case of software or hardware issues, what kind of support or replacement is provided?
  • Is there any service fee applicable for accidental damage claims?
  • How many times can accidental damage be claimed during the AppleCare+ coverage period?
  • Will the replacement (if any) be a brand-new iPad or a refurbished unit?
  • Does AppleCare+ cover battery replacement if battery health degrades over time?
I am good bro. thank you. hoping you too. applecare+ will allow you to claim for any of the damage caused by you bro. yes all the mentioned damages are covered. kindly check our episode too.
Go with applecare+ instead of protect+ when it comes to iPad. you can get it at apple service center or by calling apple support you can activate it too.
for damages its unlimited claim in a year total of 2 years coverage period.
They replace new iPad without box or accessories as you already have them. yes applecare+ also covers battery, but in iPad so far havent heard any such issues due to its bigger battery availability. we wont experience issues in 2 years time. iPad batteries last for 4 to 5 years based on our usage.
