Audio Editing App for iPhone
Hi bro , pls suggest a trustful apps from app store for audio editing
Have you tried Garageband app bro? most beginner and intermediate level musicians use it for audio editing works in their iPhone and iPad.
no bro… im asking normal mp3 editing apps for trim & cut options… other than garageband because its app size is too large
Understood bro, if you are planning to cut the mp3 file to create ringtone on iPhone, then try this app and method
else, this one has positive reviews on App Store. give it a try bro ‎Mp3 Cutter - M4a, Music Cutter on the App Store
