Brother i have tried by resting also but again it’s showing the same . Present software update is macOS Sequoia 15.5 . And no outher third party app have not been installed.
hi bro, running beta OS in any one of the device?
Brother any one of the device means your asking in IPhone and for Mac also or ?!
iPhone to be specific bro. because you are using screen mirroring feature on mac correct? so iOS is the important one here, some banking apps also restrict when we run them on mirrored environment. is the kotak bank works normally on iPhone and you are seeing error only when using screen mirroring correct?
Or can I contact Apple service center brother?!
Banking apps are not designed to run in screen mirroring bro. they block access to the app to avoid security issues. kindly use them directly on iPhone. its banking apps side restriction bro. apple support or service center will say the same thing.
Hoo okay brother.
Thank you
