Hi bro , I am using iPhone 15 pro max with current IOS version. Last oru 10 days ah notice pannuran that iPhone battery is decreasing even when the phone is idle . Like during night time and also during in the morning… Is there any bug bro ??
hi bro, kindly share last 24 hours battery page screenshot with apps section visible. normally the battery reduce happens very slow when we have sim card inserted and system uses it for apps notifications and background processing.
let me have a look at the battery statistics of last 24 hours, that will help whether any problem there or not.
if the problem is happening suddenly then the issue could be due to network switching bro. airtel and jio both in some cities randomly switching between 4G, VoLTE or 5G band. give a week time and you will see improvements.
in our iPhone, we may set to 5G ON or LTE ON mode to prevent switching, but if it happens in particular area, then even if we set the network to particular band, it will still cause battery drain when network goes off and network search happens.
So continue using it and you will see improvement in coming days.
