Battery drain after 17.0.3 in my iphone 13
Hi Robin bro last Thursday iOS 17.0.3 update irundhen after the update battery drain overa irukudhu fble reviews pathutu than update panni iudnhen but battery usualla 2 hour usage ku 20% drain aahum but 30% drain aahudhu.
iOS 16.6 or 16.6.1 downgarade panne mudiyuma?
Please advice and also IPSW website check paninen unsigned IPSWs le katudhu
Im confused what to do Robin bro
IPSW nahh Enathu bro ?
idle graph looks stable bro. but use pannumbothu drain fastera iruku. whatsapp video call ku use pannuneengala? or just normal whatsapp chat viewing?
16 version ippo downgrade mudiyalainga. I tried and repeatedly got error. iOS 17.0.3 so far stable results irukunga. battery performance also good in my iPhone 12 model too.
Once ethukum, all settings reset pannunga, then check for 2 days how it works bro.
Whatsap video call ku use panren bro
Before also same usage thaan bro but after the 17 update draining koodeya irukku bro.
17.1 le fix aahuma bro and also how to reset the settings bro
for my usage, WhatsApp video call rare a thaan use pannuvenga. may be iOS 17 related issues a kooda irukalaam. dont worry, continue va use pannunga, charge 20% around varumbothu pannalaam bro. iOS 17.1 use pannitu irukean so far its working good overall for daily usage. facetime video calls normal la use pannuvean and so far no big issues.
