Battery drain during normal usage after ios 17.4.1
My iPhone 15 battery health is reducing fast during normal usage after 17.4.1 . Isn’t even lasting for a day
kindly share last 24 hours battery page with apps section visible bro. is there any change in your usage overall recently?
Hi bro, we should use a network that provides good coverage in our area. iOS 17.4.1 so far stable and similar to 17.4. no major changes have come with this update. But due to current summer season, we notice heating as room temperature increases. battery graph during low signal coverage especially with instagram videos, we will see it bit faster. if we are using it in good coverage area, then th reduce will be less.
as we can see from the battery graph, last charged level is 80% and that is saturday 6PM. so sunday morning around 10AM you have 57% battery left, which is sufficient to get through the full day with apps usage.
so dont worry. continue following the charging practice and it will give 1 day backup for your usage. charge the phone when it reaches 20% and you can charge it upto 80% or higher as you need it.
