Battery drain in iOS 16.3.1
Hi bro my iPhone 13 battery draining so fast not even lasting 4 hrs, what to do bro?
Kindly share battery page screenshot with apps section visible bro.
Click on Last 24 hours and share the screenshot bro. that will give better idea.
idle battery graph looks stable bro. while using battery drains faster as instagram, snapchat normally consumes more battery power. you can reinstall instagram, snapchat apps once and then perform “setitngs - general - reset - reset all settings”.
See for next 24 hours and how it works after charging your iPhone 80 or 100% tomorrow morning. start using the device and dont charge in between days. let it reach 20% and share the screenshot by tomorrow evening bro.
That will give us better understanding whether there is any problem or not.
