Battery Drain on iPhone 13 after 26 update.
Hi @iRobinPro Bro,
I had updated my iPhone to ios 26 bro to be frank i am hating the iPone after the updates bro, even it is not standing for 8hrs too getting irritated on this battery drain, and i had recently replaced my battery tooo, is there any possible solution bro….:face_holding_back_tears: :smiling_face_with_tear: :sob:
hello bro, iOS 26 does have bugs thats causing users to experience battery drain. mostly due to background apps and services usage. right now iOS 26.1 beta 4 feels much better and stable. expecting the release in 2 weeks time. similar to previous years we will see good difference only with iOS 26.1 and 26.2 updates bro.
Are you getting 1 day backup for your usage type? Charge the device around 20% level if you have more screen on time in some days.
Till apple releases fix, that will help us to see some difference bro.
No bro even 1 day it’s not coming, as I am stop using mobile due to this drain bro and 2 day back only I replaced my battery…
from the battery graph, idle time battery drain seems to be less. But I can understand the issue is mostly due to iOS 26 related bugs. we can expect fixes in upcoming iOS 26.1 and higher updates bro. We will definitely notice good difference after a week of its release once background tasks settled.
I normally suggest to wait till iOS 26.1 or 26.2 update release in our videos for that particular reason.
Just to be sure that it runs good on older devices.
