Battery drain without using iPhone
Hai bro screenshot ah parunga. Night sleeping la check pannunm pothu battery 56 something early morning its comes 25 enaky innum one month la warranty mudiyuthu my model iphone 15 ethu battery issue vaa eilla latest os update ah bro
this is not normal bro. do perform “Settings - general - reset - reset all settings” once. then check how it works. iPhone model and current battery health percentage bro?
Iphone 15. 88%
once all settings reset perform pannunga. then see how it works for 3 to 4 days bro.
Mm ippathaan Panney bro and wait panni pakkure
sure bro. 3 to 4 days apram battery page screenshot share pannunga. same as above. will give us good idea.
Bro sorry ungala disturb panren. Nit data eillathaiyum off pannitu vaikum pothu charge 76% appa time 1.30am. And morg oru 6.30 enthituchu pathen battery 61% what i do 3days use pannavaa eilla veraa ethavathu sollution irukaaa screenshot check pannungaa
No problem bro. naan online la varumbothu questions ku reply pannidarean. issue irukunga. once phone backup eduthutu iOS Restore pannurathu recommended bro. Laptop use pannureengala?
Office la min mac use panren bro
And last week thaan jio la irunthu bsnl ku port change pannaey. Enga area la towers vittu vittu varuthu ethanala ethum problem irukumaaa
Just noticed bro. if you are not receiving good signal reception over the night, then its possible to see reduce of battery drain overnight or when the phone is not in usage. You can check once by testing when you have good coverage in the area you are in.
That will show good difference.
Right now with mac mini iOS Restore can be performed. But dont do it now. It wont help if we dont fix the network first. We need to use a network that gives good coverage in your area. can you do that bro?
Hai bro good morning I noticed bro yesterday i put airplane mode now i check my battery its down to 3percentages only
Then its clearly low signal coverage bro. no need to do iOS Restore now. you have to get the SIM Network that is providing good coverage in the place you are staying bro. that will help this fast battery drain overnight or when not in usage.
Bro ennoda mobile iphone 15 plus athula 32 cycle count laya 98% vanthuruchu bro
Ithu normal a drain aaguratha bro enakku thrla bro naa new to iphone
hi bro, how is your usage? gaming or heavy usage with more screen on time? also following charging practice?
Neenga sonna practice tha bro follow panran
20-80&90 one day ku one time tha charge pannuvan heavy games la play panna mattan half an hour in a day everyday screen on time 7 or 6 hrs tha bro irukkum mostly snapchat and ig tha athigama use pannuvan ithukku munnadi oru ios update pannan athula 1% drop aanuchu ipo update pannan another 1% drop aagiruchu
But this under 2 months 2% reduce is not normal bro. 5 to 6 months use pannunga. suppose battery health fast drop aachuna within warranty period we can get it checked at apple service center once.
same charging practice follow pannikonga. that will help over period of months. iOS software update reason illainga. normal la update pannumbothu bug ethvathu iruntha battery health refresh agalaina aagumnga. so dont worry about software update.
Ok bro thnx bro
