Hi Robin bro ,I am using iphone 15 pro max for past 6 months ,My daily screen time is 1 hour(max) per day ,very rarely I use it for 1.5 hours and I followed all the battery saving tips told in your videos ,till last week my battery health was in 100% ,all of a sudden it dropped 3%.
After 17.4.1 update, But the thing is my total battery cycle count is just 72 from my date of purchase. In past 6 months i have full charged only 72 times.
I’m totally disappointed with this update, bro.
Is this normal, or is there any manufacturing defect in my battery?
hello bro, 17.4.1 does have some battery performance issues as per our users reported. But main reason being the instagram, facebook apps. overall your battery health management is good for 6 months 3% reduce.
if there is defect you will see fast reduce of health bro. within 1 year we will see it reduced to 80%.
so dont worry. simply follow charging practice as suggested.
use original or mfi cable always.
charge when the phone reaches 20%. thats all enough.
drain issue will be improved in upcoming updates bro. dont worry.
in total 10 months usage bro. 7% reduce is totally normal. kindly check.
charging practice continuous a follow pannikonga. 2.5 years average time varumnga to reach 80% battery health. use the way you want and it will be maintained bro.
