Battery health reduced after iOS 18 update
After updating to IOS 18 battery health reduced 100% to 98%. Is it normal?
When we update ios, the battery cycle counts will be refreshed and display the battery health correctly bro. No issues if it’s reduced after 1 year use. But if it reduce more as unusual better to check with apple care
it must be a refresh bro. calculate battery health as suggested in this episode. that will help.
VoLte option remove akidu after this ios18 update
On ios 17 volte option iruntichu
Network settings reset panni patan still anta option ila
may be some changes made in iOS 18 bro. but if the network provides true VoLTE then you will see LTE. otherwise it will show 4G only. not a problem you can use 4G or 5G based on network providing service.
