October 9 2023 mobile purchase pannirundhen
Last month starting varai 100 dhan irundhuchu sudden ah indha month mattum 3% koranjurukku donno why and what to do?
Hi bro, I assume you are following the suggested charging practice in our video. continue the same. For 4 months usage 3% is totally normal. some months it wont reduce. Charging practice will help to maintain it overall to get that 2.5 years limit bro. measure battery health 5 to 6 months once. that helps us to understand the reduce better.
Okay thanks bro
as the phone is still under warranty, dont worry bro. even last week before warranty ends, you can check once with apple service center to identify any defect is there or not. if found they replace it for free. else it wont reach 80% limit within 1 year. continue following the charging practice and see how it goes.
