Bro kindly suggest best charger for Iphone 16 pro max, can support 40W charger
also planning to buy
https://www.amazon.in/gp/product/B0DFTN2KTY/ref=ox_sc_saved_image_3?smid=&psc=1
kindly advise proceed purchase.
hi bro, the link you have given is 15W wireless charger. are you planning to get wireless or wired charger?
In home i need to use wired charger, above magface link for office use.
i just brought 16 pro max
Apple 30W USB-C Power Adapter is a reliable choice for my personal use.
if 15W is sufficient then you can choose this one or any other branded onces bro. Raegr, Ambrane etc., Qi Certified chargers are good to use.
