Suggest a iPhone 17 best charger for battery health
any branded charger is good to use bro. it wont affect battery health. continue following the charging practice as suggested in our video. thats enough to maintain over months of usage. it will gradually reduce over 2.5 years period to reach that 80% level.
Thanks for suggestions sir …
Which one is right choice 20 w or 30 w charger
for 17 model 30W is good to use bro. only if you are ok with average speed charging 20W is sweet spot to consider.
