I have recently purchased iPad Air M3 13”, and looking for a best reliable compatible pencil. Can you recommend a pencil under ₹2000.
hi bro, you may check with ESR pencil
I couldnt find the specific m3 mention in their spec, but this is the only alternative we have right now. tukzer stylus is there too they mentioned ipad air 5th gen compatibility.
They mentioned only upto iPad Air 2022 5th gen model. but do check return option and go for it, if its not compatible then you have to return it with amazon and get refund bro.
