I’ve been using the iPhone XR for the last 6 years and I’m planning to upgrade. I’m considering the iPhone 15 Pro, 15 Pro Max, or the iPhone 16 Pro. I’m mainly looking for a compact phone with good battery life, as I mostly use it for social media and YouTube. Which one would be the best upgrade for me?
hi bro, for compact usage 15 pro and 16 pro will be good choice. but if you need to use it for more video streaming purposes then going with max model will be wise choice. do experience both device personally at nearest apple showroom. feel how the handling feels overall and based on that you can choose bro.
from XR any iPhone 15 and 16 models are considered as upgrades bro. also check 16 plus at showroom if you are ok with 60Hz Display. that will help to decide. for better battery performance plus or max models will be good bro.
for average usage 15 pro and 16 pro are suitable bro.
Thanks, brother. Is 128GB or 256GB storage fine? If the Pro Max 256GB is okay, because I plan to use it for at least 4-5 years. Currently, I have an XR with 64GB and typically back up all my photos to Google Drive and then delete them from my iPhone.
bigger the storage is always better bro. if budget allows go with 256GB Storage if you are planning for long term usage. whichever storage model you choose its important to take backup of your data to cloud storage or local as per your choice. keeping all the important photos, videos on the device is not recommended.
you are already using google drive, which is good practice. continue with it bro. incase of 4K video recording higher storage options are useful though.
