Best Lightning to USB 3 Cable MFi Certified suggestion
Lightning to usb
Best lightning cable to usb 3 with mfi certified cables suggestion panunga plz
Amazon Basics MFi cables are the best to consider bro. From my personal experience, they work veryu well and durable then default apple cable we get in the box.
https://amzn.to/3AYAanR
You can choose between USBA and USB C to Lightning Cable from the list.
This cable works fr iphone13
yes bro. for all iPhones and iPads with lightning port. Kindly read cable description and decide with your purchase bro. Duracell and other brands also there. but you can choose amazon basics cable according to the adapter you have.
Thank br
