Bro… I’m planning to buy Samsung T7 shield or T9 specially for my iPhone backups … I want to connect directly with my phone… do u have any suggestions?
Also themes and icons customise pandrathukkum oru nalla option eruntha sollunga
T7 itself sufficient for most of our usage bro. only with iPhone 15 models we can connect SSD directly. not possible to do it with iPhone 14 series or earlier models.
Customisation is not possible in iOS bro. did you just bought an iPhone? which model?
1 year aachu bro… iPhone 14 Pro Max …found some themes icon pack apps in AppStore … so thought of checking with u before installing
Kindly share any link of such themes bro. If it requires profile installation then avoiding is good idea. else you may try if its shortcut creating method just to use their icons.
Thanks a lot bro… also just wanted to know, is it not possible at all to use SSD with iPhone 14 Pro Max ? I thought we can use ‘ Lightning to USB 3 Camera Adapter’ to connect the SSD directly with my iPhone. Konjam intha product compatibility check panni sollunga bro
Welcome bro. we have to power up the storage separartely with lightning to usb c camaera adapter to make the ssd work. its an expensive accessory and instead we could try some additional wireless methods. Lightning port has its limitations and only with latest 15 models USB C we can use ssds without issues.
my suggestion is to not consider a lightning adapter for SSD usage bro. only for pen drives it will work and we could get cheaper OTG adapter to use pen drives.
Got it bro… thanks a lot ![]()
Pesama laptop’la connect panniyae transfer pannidrae… I think that would be better
… just iPhone things ![]()
True bro. Lightning port is limited to output power. 5W limit I think. thats why most accessories are not working. My suggestion is to consider Transferring it to system and then to portable drive.
Really helpful bro. Thanks a ton
