Hi bro,hope you are doing well.I am in a search for good temper glass for my iPhone 13 .Amozo brand temper glass is not having full screen coverage for iPhone 13 they have a cutout for the notch which I don’t like.can I go with Czartech brand that you recommended 4 years ago which I will share the link ,you just check it and tell me whether this is that you told 4 yrs ago or which brand shall I goo?
I am good bro. thank you. hoping you too. Czartech is the one I mostly prefer bro. yes go for it. do you mean this type of tempered glass bro?
This one bro. https://amzn.in/d/0FlFT0v. Is it good?will this screen protector give edge to edge coverage.I play BGMI game more.so the screen protector should give me full coverage,should be seamless with fit,should not have a big cutout for the notch,should have black border,should have small cutout for the receiver.currently I am wearing totem silicone case which has a raised lip for the screen with a temper glass giving full coverage that has a black border ,a small cutout for the receiver.I need screen protector like this one bro.The one you showed is not having black border.The screen protector which I am buying should not be disturbed by the totem silicone case,and The screen protector link which I shared will satisfy my needs? or do you have other options?I will attach my current case and temper glass photos for an idea…
Got it bro. above one is clear type tempered glass only. so it shouldnt be a problem with fitting while using cases. many people are using it. do check user reviews on amazon once too, and then order it.
