bro which brand tempered glass is best for iphone 15 pro max , black border ulla madri vanguna display besel size screen size reduce aguma, or plain glass recomendeda enda tempered glass is best bro 15 pro max, neenga yada madri tempered glass use panringa , black border or plain white glass which brand
Both are good choice bro. apply pannurathu correcta pannuna both will not interfere in the display area. mobile shop la kuduthu screen protector apply pannuravanga iruntha pannunga in a place no dusts. or you can apply it yourself following our video tutorial
Frame model is not available on amazon now. Out of stock.
Here is no frame model.
Spigen align master ok va bro 14 pro max
Yes bro. its good too. branded and good with applying kit.
