I m using 14pro max and 15. Suggest me a good tws sony c510/bz or beats solo buds tws @iRobinPro
hi bro, beats as an apple product has some integration into iOS. It has decent bass level and good battery life for music listening. meant to work with both iOS and Android. it has find my integration too.
So if you are looking for something that goes well with iPhone choose Beats solo buds. People prefer sony for its brand specific choice. we have to manually connect with iPhone but once paired it works good in terms of audio quality.
Check user reviews of C510 on amazon and then go for one bro.
