Hi bro Ennoda Bike la 5w Charging Port irukku , Athula Apple oda USB A to Lightning Cable la iPhone 13 Charge Pannalama ? ; Ethachum Problem Varuma ?
hello bro, ithuvaraikum bike charging port try pannathu illainga. but I think its same as Car Charging port. power fluctuation irukumanu once electrical work panuravanga kita check pannikonga. mathapadi lesser watt use pannalaamnga. Original or MFi cable eppothum use pannunga. 2 to 3 weeks use pannunave issue iruntha cable problem pannumnga. appo neenga usage stop pannikalaam. otherwise continue va thevaipadumbothu use pannunga bro.
USB A To Lightning Cable Mfi Certificate la Oru Nalla Cable Solluga bro , Bike la Mattum Use Panra Mari.
you may try this amazon basics cable bro.
Not durable as their Rs 900 worth cables, but suitable for basic usage purposes. Only if budget isnt a problem consider their nylon fiber cables. they are more durable.
